In other editors you can see, which compression level was used for the image conversion and it seems XnView misses such feature. Can it be implemented? It very useful and this far it is the only XnView's drawback comparing to others as for me.
Thanks for the great tool anyway!
Suggestion - JPEG compression quality info
bodydomelight
- Forum Librarian
Re: Suggestion - JPEG compression quality info
In addition to the compression level (Q-factor), I'd like to know what the chroma sub-sampling is and whether I'm dealing with an progressive (interlaced) or baseline encoded JPEG.
- Forum Librarian
Properties for JPEG files in v0.53:
- Progressive mode
- Sub-sampling [new]
- Estimated quality [new]
