XnView on Roozz
XnView on Roozz
Do you want to use XnView from a web browser? :)
Now it's possible with Roozz plugin
Peter2
Re: XnView on Roozz
Post by Peter2 »
Hi Pierre
to you have more infos?
What or who is Roozz?
Can it be uninstalled? (Is it "installed" or "activated" or ...)?
Which Browsers are concerned?
Thanks
Peter
Re: XnView on Roozz
Roozz is a company, the plugin can be installed on IE&firefox, only on windows
I think that the plugin can be uninstalled...
Peter2
End user info
Post by Peter2 »
End-users
Getting Started
http://www.roozz.com/node/5
Peter
JohnFredC
Re: XnView on Roozz
Post by JohnFredC »
Installation fails on my XP w/Firefox 14 system. Something about the updater.
John
