I have created a batch script to convert all photos in a folder ex. C:\photo\*.jpg, that resizes them all to 640x480 and have saved it. Is there a way I can call and run this script from the command line and then automatically exit the program.
thanks
Dave
Batch Processing via command line
Re: Batch Processing via command line
you can export the script to use with NConvert
