nconvert -overwrite -buildexifthumb problem
dodfr
Post by dodfr »
I wanted to recreate exif thumbnails of a bunch of jpeg but I noticed that nconvert also recompress the jpeg itself (with higher compression ratio) ... this is bad, is there a way to avoid this default way of work ? nconvert should not touch original jpeg image/compression if not explicitly requested.
Regards.
Re: nconvert -overwrite -buildexifthumb problem
yes it's not lossless operation, i'll add a lossless one...
