I am installing xnviewmp in Ubuntu 12.04 Precise Pangolin. Because I have multiple disk partitions containing different Linux distributions, I have a separate partition in which I keep all my data that I want to share among OS's. I would like to put all my xnviewmp files on that partition including configuration information, databases, etc. I see that under the Settings>Integration window there is what appears to be a way to set file locations. However, when I change them, it has no effect. I suppose this is because xnviewmp has already set up its files (I can see them with Nautilus file browser), before I change the location setting. I see the following files in my Home directory: XnView.db, .xnviewmp/xnview.ini.
How can I get these files established in my Data_Partition?
Thanks in advance.
How to put xnview files where I want them
ralphl
Re: How to put xnview files where I want them
Anybody got ideas on this???? I sure could use the help!!!!!!
Ralph
Ralph
you have option>Integration - Settings
Vapavite123
Fichiers doublés (pas de suppression des fichiers inutiles après changement)
Duplicated files (not delete unnecessary files after change)
