I have a question and an potential bug to report.
My question is: can you assure me that pushing the quality slider all the way to 99 is truly lossless?
The reason why I ask is because the slider in XnConvert only goes to 99, whereas in Photoshop it goes to 100 and also has a Lossless checkbox to select that disables the slider. This implies that 99 is "not quite there".
The potential bug: ICC profile information is not being preserved when converting from TIFF to JPEG XR.
thanks
JPEG XR Support
Re: JPEG XR Support
yes right, must go to 100
Paul Coddington
Re: JPEG XR Support
So, to clarify, it is not possible to convert to lossless JPEG XR in the current version?xnview wrote:yes right, must go to 100
Re: JPEG XR Support
yes, you can try to 1.50 beta
