1.50 b: "Convert with XnConvert"
budz45
Post by budz45 »
Thank you Pierre for adding the "Convert with XnConvert" shell context menu feature :)
(user must enable it in 'Settings')
Clipboard 1.jpg (32.65 KiB) Viewed 4416 times
Right, but currently now in v1.50 beta, this shell item is only usable for when right-clicking on folders...
....Should it be supported for right-clicking on image file(s) too? I think it should 8)
budz45
Re: 1.50 b: "Convert with XnConvert"
Post by budz45 »
Pierre, could you add support for using this with image Files in windows explorer (selecting multiple image files) ??
budz45
Post by budz45 »
Pierre,
The "Convert with XnConvert" is not working at all in v1.51 :( .....The menu displays when right-clicking on a folder but when selected XnConvert opens but loads no pictures.
Also as aforementioned stated, the "Convert with XnConvert" must show when right-clicking on image files too in win explorer.
and work with 1.50?
budz45
Post by budz45 »
xnview wrote:and work with 1.50?
nope :(
...Please also you must activate it to work with selecting image files in windows explorer, just like how XnView Shell Extension is activated for working with image files in windows explorer.
nope :(
Never worked???
budz45
Post by budz45 »
Affirmative, sorry it never worked. :(
I also just did a quick first-time test of this in my Windows XP virtual machine and it still does not work. :(
So the feature needs to work for both right-clicking on Folder (images in folder, not sub-folders) AND needs to also work when right-clicking on File(s) in win explorer.
Hmmm... But if I drag & drop one or more image files to XnConvert.exe , then XnConvert loads the files but displays the "Action" tab instead of showing the "Input" tab, so this needs a small fix too, so that it always switches to "Input" tab when launching files via the XnConvert.exe method <-----------> after this fix then it would be easy to fix the 'Convert with XnConvert' shell context menu issue, since all the shell menu is doing is simply linking and opening with XnConvert.exe :)
Hope you understand Pierre
btw, for when running on Windows XP could you add a standard bitmap 16x16 icon (xnconvert) for the shell context menu, it needs to show on Win XP users too. Thank you.
budz45 wrote:Affirmative, sorry it never worked. :(
I've tried with a Xp, start XnConvert (not admin), click on 'Add convert with ...', close
And now in windows explorer, i have 'convert with XnConvert' in context menu on a folder
budz45
Post by budz45 »
Pierre, the context menu itself does show yes that is not the issue.
The issue is that when I click on the context menu item, it does not load the image files of folder into the opened XnConvert.
Also this feature SHOULD also be fixed to work with right-clicking on selection of files (images) too.
budz45 wrote:Pierre, the context menu itself does show yes that is not the issue.
Right %1 is missing in the registry
Currently i have problem with that...
budz45
Post by budz45 »
In theory there should be no problem with this....Because I am currently able to drag & drop files (images) to xnconvert.exe and then the program opens and loads the files correctly :) However this drag & drop to exe method results in the 'Actions' tab being shown instead of the 'Input' tab :?
