Mac: Thumbnail Scrolling Speed (Too Fast!!)
jadik
Post by jadik »
I was seeking an application that allowed me to quickly view all of the thumbnails in a collection. XNviewMP for Mac, finally presented a reasonable solution... and then some!
Scrolling within the Thumbnails pane, however, is radically fast. What I mean is that scrolling thumbnails is *way-too-fast* to keep up with. After looking through the forum & all the app features, it seems that there is no way to control this scrolling speed. When I change the trackpad scrolling speed at the OS level, in my Mac "Preferences" pane, under accessibility (something I shouldn't have to do), it reduces the scroll-speed for the other file/folder/feature panes to a crawl. While it would be nice to have the ability to control this speed, it wouldn't be necessary if it operated at the normal "on-demand" rate of most other applications (i.e. Finder, Safari, Chrome, Word, etc.).
It seems this must be a bug, since the rest of the application manages to scroll at entirely normal speeds & the thumbnail pane has perma-hyperwarp-scrolling-speed.
Please take a look at this and address this as appropriate.
Cheers,
Jadik
Daf
Re: Mac: Thumbnail Scrolling Speed (Too Fast!!)
Post by Daf »
Hello, Developers!
Thank you for a wonderful program! For the Mac system better viewer not developed.
I have a few questions and the first is a too rapid scrolling, as the author of this topic.
Scrolling scrolls in my case three lines instead of two on the screen, one line is skipped.
In other programs, all right scrolling. Make the setting for his kotrol, please!
I want to know whether it is possible to make a more visible line of the selected images? They are poorly visible.
Also not finalized category for MAC.
Clavey combination shift + CMD + Shift +3 and shift+4+CMD busy system under the screenshots.
I would like to see the selection of colors throughout the cell, as in adobe bridge.
Thank you!!!
Daf wrote: Scrolling scrolls in my case three lines instead of two on the screen, one line is skipped.
You can disable Option>Browser>View scroll the content...
What do you means?
