Metadata: 4 Options to enable/disable
Peter2
Post by Peter2 »
Using IPTC I found 4 options on 4 different places to enable or disable them. A little bit confusing :? :? :? :?
Without a manual not easy to use.
Peter
Re: Metadata: 4 Options to enable/disable
Ok, for EXIF/IPTC/ICC option in "Write settings", i'll remove them...
But i don't understand what you mean with the 2 others screenshots?
Peter2
Post by Peter2 »
xnview wrote:...But i don't understand what you mean with the 2 others screenshots?
The simple question is: wrote:What happens with which option?
I don't have any idea which option influences the others.
Peter
'Enabled' is to enable the action in the process
'Keep new values' is to merge keywords if the file have some already
