Thumbnails & .XnViewSort
Zheitk
Post by Zheitk »
a) A button to rebuild missing thumbnails http://newsgroup.xnview.com/viewtopic.php?f=62&t=26330
  • I don't know what the "rebuild thumbnails" and "refresh" do, they seem to do nothing in this case :P
b) A button (maybe the same one) to sort the thumbnails to the default (by filename in my case)
  • In fact, I don't remember if there's an option to set a default order...
c) Deprecate the ".XnViewSort" file and use a database instead
Re: Thumbnails & .XnViewSort
You means XnViewMP?
Zheitk
Post by Zheitk »
oh my... :shock:, should I have posted this in the "MP Testing - Feedback" didn't I?. If that's the case, ¿how could I move this (and another 6 posts :mrgreen:)?
Zheitk wrote:a) A button to rebuild missing thumbnails http://newsgroup.xnview.com/viewtopic.php?f=62&t=26330
A bug
You have order by filename
Why? :)
Zheitk
Post by Zheitk »
xnview wrote:a) A button to rebuild missing thumbnails http://newsgroup.xnview.com/viewtopic.php?f=62&t=26330I don't know what the "rebuild thumbnails" and "refresh" do, they seem to do nothing in this case
A bug indeed T_T, but you can tell me then what those actions are supposed to do (without taking into account the bug)
xnview wrote:b) A button (maybe the same one) to sort the thumbnails to the default (by filename in my case)In fact, I don't remember if there's an option to set a default order...
If the pics were moved (or newly added, those are sent at the bottom of the browser) it would be useful to "refresh"O_o? the browser view (rearrange by filename) with just one button, as right now you have to select the "sort-by" menu, then the "Name" or preferred order, and then (maybe) the ascending or descending way, then another one to rebuild missing thumbnails...
... thinking about it, clicking the sort-by button (the green arrows, not the little triangle) does nothing, So It would be useful to let the user bind some actions to it (like sort-by preferred order and rebuild thumbnails in the same button ñ_ñ, (and maybe delete .XnViewSort if present, see below))
xnview wrote:c) Deprecate the ".XnViewSort" file and use a database instead
Just a recommendation, not really important... I used to really hate those bastards Thumbs.db in windows XP :twisted:
PD: thanks for listening to the users, I tested so many similar softwares and find some Ideas that I would like to see in future versions of xnview, So I feel happy using it ñ_ñ
