Thumbnail orientation doesn't match image
brava
Post by brava »
I'm viewing .tiff files, and all thumbnails come out as landscape while image comes out correctly as portrait. All files are portrait, and have EXIF data. I tried turning off embedded thumbnails, cleared cache, rebuilt thumbnails, as well as tried to convert lossless jpeg EXIF (which doesn't work because all these files are .tiff).
I reviewed this: http://newsgroup.xnview.com/viewtopic.php?t=1420 but still can't get it to work..any other ideas? Thanks!
Re: Thumbnail orientation doesn't match image
obelisk
Post by obelisk »
I get this somtimes too
usually the thumb is right and then due to a memory leak the img preview either rotates or is stuffed up
happens after previewing 50 large files or about 250 12MP files.
so definitely due to file size
