Toolbar: Position & Configuration
klumy
Post by klumy »
- option to move up and move down the toolbar icons
- rightclick on the toolbar should open a contextmenu with the option to configure the toolbar
XNView 1.91.5
Windows XP SP3
Re: Toolbar suggestion
Thank you, klumy, for your suggestion.
klumy wrote:- option to move up and move down the toolbar icons
Do you mean that it should be possible to position the toolbar on top or on bottom?
klumy wrote:- rightclick on the toolbar should open a contextmenu with the option to configure the toolbar
Toolbar configuration is possible in Tools > Options > Toolbar > Buttons displayed. Sure enough this is a bit complicated to find and use, perhaps your right click configure approach can be implemented.
klumy
Post by klumy »
no I mean to change the order of the toolbar buttons like in Windows Explorer
XNView 1.91.5
Windows XP SP3
O.k., I understand.
Dreamer
Post by Dreamer »
I support this request.
Re: [REQ] Toolbar: Position & Configuration
Ok, i'll try to add it.
klumy
Post by klumy »
XNView 1.91.5
Windows XP SP3
klumy
Post by klumy »
there should also be additional toolbar buttons for "Save" (not just "Save as") and Rotate images
XNView 1.91.5
Windows XP SP3
