capture screen issue
pawel
Post by pawel »
Hi Folks,
Recently I have discovered that when I capture a screen, no mater what capture area, method or option like single capture or multiple.
I capture one screen and then I choose Capture screen again to capture next screen but the new capture overwrite the first one and so on
no matter how many captures I do in the end there is onlyu one captured screen the last one I did.
It never happend earlier and before my discovery, couple days a go, I could capture several screens one by one or multiple capture and all images was saved with new name or number.
I have not changed any settings or anything else for that matter, I have no idea what ois going on and why it happend.
All ideas welcome.
Pawel
Drahken
Re: capture screen issue
Post by Drahken »
Look at the filename field on the screen capture setup dialog and see what it says. It should be something like "capture_[mdY_HMS]" (minus the quotes), with the part in brackets being the part that gives each capture a unique number. I'm guessing that that part somehow got removed or altered at some point.
