- press Ctrl+C (or use menu) in Viewer
- go to browser or file manager
- press Ctrl+V
= it doesn't work
1.80 PR1: Copy - Ctrl+C doesn't work in Viewer
In the browser you work with files (file browser), in image view you work with an image. So this is consistent and should be clear to users...Dreamer wrote:OK, but users might expect Ctrl+C works same as in the browser...marsh wrote:It copies the image not the file. Try import clipboard and see.
ckv totally agree.helmut wrote:In the browser you work with files (file browser), in image view you work with an image. So this is consisten and should be clear to users...
