Wrong colors with colorspace "European Print Medium"
rcpinheiro
Post by rcpinheiro »
Hi!
I'm trying to open a lot of images that use the colorspace "European Print Medium GCR, 320 UCR". Unfortunately the colors are wrong on XnView, although Google Chrome and several other programs have the same problem. Photoshop displays the colors OK and PaintShop Pro converts the colors to RGB and then they appear fine.
Here's an example:
it should look like this:
But looks like this instead:
I don't know is this is a bug or an unsupported colorspace but if it's the later, please add this colorspace in future releases.
Thanks in advance!
Re: Wrong colors with colorspace "European Print Medium"
Could you send the file?
rcpinheiro
Check PM :)
Do you have enable option>ICC
rcpinheiro
Ah, it works, thanks!
Just for reference: Tools->Options->General->ICC->Use ICC Embedded
It does slow down considerably the loading of large images. I wonder what kind of voodoo Photoshop and PaintShop Pro do to load the images with this ICC as fast as any other...
