in advance: I use xnview with German explanantions, so I'm not allways sure if I use the right English word.
I organize my photos with xnview, attach the photos to categories and assessments.
Now I want to change the folders of my photos. For example move the photos to an external disk.
But if I do so, all the categories and assessments are lost.
What can I do?
Thanks for your reply!
majaontour
Move photos with categories and assessments
majaontour
Re: Move photos with categories and assessments
You can move photos with XnView?
Or if you know a little database, i can show you how to modify the database...
majaontour
yes I like to try - thanksxnview wrote:You can move photos with XnView?
move to another folder etc.
majaontour
Thanks. I load category.db into SQLIteDatabase browser and could make the changes sucessfull and saved.xnview wrote:here is http://newsgroup.xnview.com/viewtopic.p ... ser#p85799
Now XN-View does not show the categorys of the photos anymore. I closed xnview.
Then I removed the pictures to the new folder. (This I did not with xnview)
I started xnview again. But XN-View does not show the categories.
What was my mistake? Must I also do changes is the 'xnview.db'?
Thanks for Help
The category pane is empty??
majaontour
yes - the last window on the right side, where you can see, which category is choosen for the photos, nothing is marked anymore.xnview wrote:The category pane is empty??
When I copy my saved unchanged 'category.db' back and the photos back to original folder, I can see the marked categorys again.
Do you have an idea?
could you send me the changed category.db?
