1.8PR: View not updated when scrolling
Locked
Olive
Post by Olive »
This has appeared in RC7.
1 View>fit image to window width
2 dbl click a thumbnail to view it (in viewer, not fs)
3 hold right-click and scroll
--> the image is not updated, it's "tiled" (screenshot)
Re: 1.8PR: View not updated when scrolling
Olive wrote:This has appeared in RC7.
Strange, i have not this bug??? You have it always with "fit image to window width"??
marsh
Post by marsh »
Confirmed, I see image tiling with 'fit image to window width' and Browser>Viewer>Fullscreen mode. I have not seen it happen with Browser> Fullscreen>Viewer mode.
ckit
Post by ckit »
I cannot re-produce this bug.
Make sure your About Dialog box says Jun-17-2005 or later.
Olive
Post by Olive »
Yes it always happens with the first file I view.
New ini + fit to window width + resize window to have vertical scrollbar
Preview seems okay it's just view
6/17 build
ckv
Post by ckv »
Confirmed
everybody try this
- right-click on tab bar to empty area (don't click any tab) or when doing dbl click, don't release mouse button after second click
- and scroll with mouse scroll
Edit:
If the bug don't still occur, try again and do everything straight on the start.
marsh
Post by marsh »
An easy way to recreate problem:
1. Use Browser <> Viewer Mode.
2. Use View>fit image to window width option.
3. Select picture. Go directly to viewer mode.
4. Quickly after step 3, move picture up and down. Problem occurs here.
(If you wait a long time between steps 3 and 4, the problem will not occur).
marsh wrote:An easy way to recreate problem:
Yes, now i can reproduce it...
marsh
Post by marsh »
Fixed in v.1.80
Locked
