[1.50β] Spin controls and decimal increments
When I add “Gammasat” to the actions, the spin buttons make the intensity jump from 1.00 to 2.00 etc.
I'd expect it to increase/decrease in decimal increments (as with the “Rotate” action).
Re: [1.50β] Spin controls and decimal increments
right
{{7*7}}
This bug is fixed in the final release.
There are still a few issues remaining, though:
  1. The reset button has no tooltip.
  2. When I highlight or delete the value in the field for Intensity and start typing a new value, .00 is added automatically.
  3. The scale for Intensity ends at 5.00, but the value can be increased up to 99.99 with the spin controls.
  4. This is what happens if I manually enter 0.07 into the field and then increase the value with the spin buttons:
    • 0.07/0.17/0.27/0.37/0.47/
      0.56/0.66/0.76/0.86/0.96/1.06/
      1.12/1.22/1.32/1.42/1.52/1.62/1.7/1.82/1.92/2.02/2.12/2.22/
      2.31/2.41/
      2.50/2.60/2.70/2.80/2.90/3.00/3.10/3.20/3.30/3.40/3.50/3.60/3.70/3.80/3.90/4.00/
      4.09/
      4.18/
      4.26/
      4.34/
      4.43/
      4.51/
      4.59/
      4.68/
      4.76/
      4.84/
      4.93/
      5.00/5.10/5.20/5.30/5.40/5.50/5.60/5.70/5.80/5.90/6.00/ etc.
XnTriq wrote: [*]When I highlight or delete the value in the field for Intensity and start typing a new value, .00 is added automatically.
[*]This is what happens if I manually enter 0.07 into the field and then increase the value with the spin buttons:
Here it's a Qt widget problem....
{{7*7}}
xnview wrote:Here it's a Qt widget problem....
Thought so :|
XnTriq wrote:
  • The scale for Intensity ends at 5.00, but the value can be increased up to 99.99 with the spin controls.
This bug is fixed in v1.51 :bugfixed:
