[Fixed]1.8PR 'fit image to window height' does not work.
Locked
marsh
Post by marsh »
'fit image to window height' does not work. It looks like 'fit image to desktop'. It looks like 'fit image to desktop' in fullsreen, also.
Fixed. v.1.80.2RC
Re: 1.8PR 'fit image to window height' does not work.
marsh wrote:'fit image to window height' does not work. It looks like 'fit image to desktop'. It looks like 'fit image to desktop' in fullsreen, also.
Sorry don't understand. Which option do you have for view & fullscreen?
Fullscreen from view mode? What's happened??
Post by Guest »
Browser>Fullscreen>Viewer
View> 'fit image to window height'
View>Fullscreen>'Like view mode'
I cannot get 'fit image to window height' to work at all. There are no horizontal scroll-bars. It is identical to 'fit image to window, large only'.
With:
View> 'fit image to window width'
I cannot get 'fit image to window width' to work right in fullscreen. The scroll bar is missing in fullscreen (even when I selected not to hide them). Also, there is always an empty space where scroll-bar would have been (image does not fill entire screen).
Olive
Post by Olive »
Seems to work for me. Well it looks like 'fit image to desktop', but if you resize the window enough the horizontal scroll bar should apprear.
Ok, i have reproduced the problem...
Post by Guest »
With Videos it is the same in the pre-view window they don´t use the settings for videos anymore in 1.80
Locked
