Actions menu
Actions menu
There's enough space in the Actions tab to spread out the submenus:
  • [ Image ± ] [ Map ± ] [ Filter ± ] [ Misc ± ] · · · · · · · · [ Clear all ]
Re: Actions menu
But with translation, the menu label can take more space :(
Re: Actions menu
Right, I forgot about other languages.
Re: Actions menu
XnTriq wrote:Right, I forgot about other languages.
so perhaps an icon??
Re: Actions menu
Yes, would be great if Yuri “donated” icons for that :-)
Re: Actions menu
Do you have idea for icons? (Image/Map/Filter/Misc) to help yuri
Re: Actions menu
xnview wrote:Do you have idea for icons? (Image/Map/Filter/Misc) to help yuri
Those are really tricky :|
  • Image
    • Add mask, Automatic crop, Canvas resize, Change color depth, Clean metadata, Crop, Extract channel, ICC convert, IPTC/XMP, Mirror, Replace Color, Resize, Rotate, Set DPI, Text, Vignetting, Watermark
    Map: brightness + contrast or palette/colormap
    • Adjust, Align histogram, Automatic contrast, Automatic levels, Color balance, Conbright, Equalize, Exposure, Gammasat, HLS (Hue/Lightness/Saturation), Levels, Logarithmic Lut, Negative, Normalize, Normalize Ex, Posterize, Saturation, Sepia, Shadow-Highlight, Solarize, Swap component, Temparature
    Filter
    • Average, Blur, Edge detect, Emboss, Emboss more, Enhance detail, Enhance edges, Enhance focus, Focus restoration, Gaussian blur, Maximum, Median box, Median cross, Minimum, Reduce noise, Sharpen, Soften
    Misc: function(x) in algorithm or effects (FX) or magic wand or bag of tricks
    • Add noise, Bloom, Border, Border 3D, Crystalize, De-interlace, Fantasy, Halftone, Lens, Mosaic, Oil painting, Oil painting 2, Old camera, Photo Spread, Pointilite, Retro, Shear, Slice, Spread, Swirl, Symmetry, Tile, Waves
  • Image
