Using version 1.22 on windows XP SP3
*When using "Add Folder" to add files .jp2 files are ignored .. they are added successfully using "add files" dialog
*UI - When using "tile windows horizontally" to arrange open windows the XnConvert windows are slightly too large and overlap - this appears to be due/related to them attempting to use the whole screen, and not taking into account the taskbar. If Taskbar>>properties is set to "hide taskbar" then everything works properly - v. minor issue.
Thanks!!
two minor bugs
Re: two minor bugs
could you post a screenshot? Do you have tried the 1.50 beta?ijhull wrote: *UI - When using "tile windows horizontally" to arrange open windows the XnConvert windows are slightly too large and overlap - this appears to be due/related to them attempting to use the whole screen, and not taking into account the taskbar. If Taskbar>>properties is set to "hide taskbar" then everything works properly - v. minor issue.
