"Fit window to image" doesn't work.
darkstar_1
Post by darkstar_1 »
when I chose in OPTIONS - VIEW - "Fit window to image", it have no effect. The window does not resize to image, if I resize the image as it does in ver. 1.74.
OS: W2k Pro Sp4
Is there any solution?
Thanx in advance Darkstar
ckit
Post by ckit »
Please wait until XnView 1.80 Final has been released.
darkstar_1
ckit wrote:Please wait until XnView 1.80 Final has been released.
Isn't Ver. 1.80 06/17/2005 the final? There is no hint that it's a RC.
Darkstar
ckit
Post by ckit »
No, thats a pre-release.
The final version of 1.80 is only hours away.
darkstar_1
Ok, i'll wait, but it's hard... ;-))
Thx Darkstar
ckit
Post by ckit »
darkstar_1 wrote:Ok, i'll wait, but it's hard... ;-))
Thx Darkstar
XnView 1.80 Final is now out!
Post by Guest »
Still the same prob. in the final version :(
Did a hard uninstall of all older versions including the Registry and Dirs.
cu Darkstar
Drahken
Post by Drahken »
The window resizing works fine for me, but only if I set it within options. If I go view->auto image size->[anything], it just immediately reverts itself to whatever is set in the options.
Anonymous wrote:Still the same prob. in the final version :(
Strange for me window is resized, i have "force xnview to fit image" too
