How to replace images from a mbm file opened with XnView?
offfff
Post by offfff »
I have a music player for my mobile phone called TTPod. It's got a lot of skins and it's cool but 1 thing irritates me a lot - it has a mini player which is placed on the home screen and if the picture isn't a rectangle or a square, there is a white background around it. I know that the skins have a .xml and a .ttb file so I found a converter and converted the .ttb file to .mbm. Afterwards, I found this great software - XnView. As soon as I installed it, I opened the .mbm file and there were 102 pages of different images which the player uses when it's with this skin. I scrolled and found the image of the mini player (actually they were 2) and made them in .png format because I want to get rid of the background. Sadly, I don't know how to replace the pages in XnView and then save the updated .mbm file.
Any help is appreciated... I'm sorry for my newbie question but I can't figure it out myself. :(
Re: How to replace images from a mbm file opened with XnView
Sorry but you can't change image in mbm
offfff
Post by offfff »
xnview wrote:Sorry but you can't change image in mbm
OK, but can I somehow export all the images from the .mbm file, then replace 2 of them and create a new .mbm file? Can a .mbm file contain .png images (I'm asking because I know that MBM stands for Multiple Bitmap :|)
offfff
Post by offfff »
XnTriq wrote:
OK, thank you but is it possible for a .mbm file to contain .png images or I should give up?
offfff wrote:OK, thank you but is it possible for a .mbm file to contain .png images or I should give up?
Sorry, I can't answer your question, because I'm not an Symbian user myself.
