If I am using the 'Actions' tab or 'Settings' tab and I then drag & drop some image files to the interface, then nothing happens because I am not in the "Input" tab.
Right, so I reckon these below two enhancements should be considered:
1.) Support for drag 7 drop on 'Input' tab. The 'Input' tab should become active (highlight) if I drag some files to the 'Input' tab whilst using another tab, (see this topic on file drop 'tab highlighting':- http://newsgroup.xnview.com/viewtopic.php?f=74&t=21605 )
2.) Dragging & dropping files to any tab such as the 'Settings' tab or 'About' tab could trigger the program to display a prompt to the user which would say "Would you like to add the additional file(s)" with a yes/no choice
1.50 b: Drag & drop enhancements needed for XnC
budz45
Re: 1.50 b: Drag & drop enhancements needed for XnC
ok, i'll try to add it in 1.51
budz45
Thank you, it is now much better in XnConvert v1.51
, the interface now switches to the "Input" tab when in another tab and doing a drag & drop files
