Problem with ICC profiles
lian
I cannot get the "true" colors from my colorist (see example here http://tof.canardpc.com/view/c87ac029-f ... 0c5513.jpg). Left image is the good one: it shows right in Gimp and Windows 7 preview but not in XnView (or Fastone Image Viewer). It's a jpg image made under Photoshop. I had the problem and corrected it in options>ICC>sRGB profile. It does not work anymore. I asked for the right profile to my colorist but it's the same.
Test and strange problem: after chosing sRGB, if I rebuild the thumbnails, they show correctly. I open the image and it's correct. I open another image and go back to the first: again, the colors are not good.
SF, illustrations et mes BD sur mon blog: https://www.li-an.fr/
Windows 10 Home 64 bits
CreativeWorld
Re: Problem with ICC profiles
You can fix it with PS. Go to Edit > Convert to Profile > Destination Space and check sRGB IEC61966-2.1. Enjoy it
lian
So it have to be done in Photoshop ?
Do you have enabled ICC?
lian
Yes.
I found why it worked and not now anymore... It shows "true" colors in XN1.99 and not in MP with the same ICC options...
really?? Is it possible to have the file?
lian
You can grab it here: http://tof.canardpc.com/view/ef55bb9c-1 ... 396a96.jpg
But this file has no ICC profile???lian wrote:You can grab it here: http://tof.canardpc.com/view/ef55bb9c-1 ... 396a96.jpg
lian
It seems the file has lost its ICC profile when uploading to the site. Here is the original one: http://www.li-an.fr/boulot/temporaire/
And here is a comparison between the visual in XN and MP: http://tof.canardpc.com/view/9c1f695e-c ... 317929.jpg (sorry for another file but the problem is the same).
I have same visual in XnViewMP & Win7 Preview, the problem is with XnView 1.99 (that use an old version of the icc engine)
lian
Well the 1.99 version is the same as the Gimp version and the good one for my colorist... S
Perhaps Gimp use old engine toolian wrote:Well the 1.99 version is the same as the Gimp version and the good one for my colorist... S
lian
Maybe Photoshop too because these versions are the "good" ones. So I'm just puzzled. Must I open them with something else than MP ? I don't see any other solution.
Hum, i have same visual in PS & XnViewMP
lian
It seems to be the good version... and not what I see on my own MP.
I see this, a much more "flashy" version.
