ctrl tab direction is wrong
riow
Hi there, it's been a long time I notice that the Ctrl Tab direction is from right to left rather from left to right traditionally in worldwide software. May you please change the directions of Ctrl Tab from left to right, and Ctrl Shift Tab from right to left?
Re: ctrl tab direction is wrong
You means for Tab in XnView? Ctrl+Tab change left to right
riow
No, the truth is Ctrl Tab will be from right to left.
Drahken
If you want to get technical, you're both wrong. It goes in order of recent selection. Manually select some tabs in a random order, then ctrl+tab, you'll see it bounce around, starting with the one you most recently selected & then working backwards.
Now, since newly opened images open in tabs to the right this means that if you open a bunch of images at once, ctrl+tab will go from right to left. (At least unless/until you manually select some in a different order.)
riow
Can the order simply make it from left to right? It seems a mess! Sometimes go from left to right, but sometimes reversed, sometimes even random!
