We have a number of PDF files that we are converting to PNG for use on our website. When using our PDF program (PDF Professional Converter) we can select the resulting resolution of the PNG and get optimal results. However, when we use XnVIEW to perform the conversions (individual or batch), the conversion dialog offers no option for effectively specifying a resulting resolution that helps the text.
Worse yet, whatever resolution XnVIEW is defaulting to is producing a poor image with course text that is hard to read. We also tried specifying a DPI value on the 'Transformations' tab of 300 dpi in the conversion dialog. This creates a huge file, but the resolution of the text is not any better. Does anyone know how to control the resulting resolution of the text in the PNG file when converting from PDF to PNG? (PDF Converter can do it, so XnVIEW should also)
PDF to PNG conversions of poor quality
Peter2
Re: PDF to PNG conversions of poor quality
What are the DPI settings in "Options - General - Read/Wrtite - Read EPS/PS/AI/PDF"? Try the conversion with a higher value ...
Peter
Peter
eL_PuSHeR
A workaround would be getting XPDF and then extracting all bitmaps from PDF using PDFimages and then converting them back to PNG with XnView.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
GeForce GTX 970 (Gigabyte)
8 GB DDR4 (2100)
BlueMax
Thank you Peter, you resolved the problem for us! We had no idea that the conversion program was also modifying the SOURCE document as an INPUT. Our focus was all over managing the output. We understand the program a little bit better now, thank you again for your insights.Peter2 wrote:What are the DPI settings in "Options - General - Read/Wrtite - Read EPS/PS/AI/PDF"? Try the conversion with a higher value ...Peter
Peter2
Your welcome. Some month ago I had the same problem ...BlueMax wrote:...Thank you Peter, you resolved the problem for us! We had no idea that the conversion program was also modifying the SOURCE document as an INPUT....
Peter
DOS386
Alternatively, use PDFDRAW tool from MUPDFeL_PuSHeR wrote:A workaround would be getting XPDF and then extracting all bitmaps from PDF using PDFimages and then converting them back to PNG with XnView
eL_PuSHeR
Intel i7 5960X
8 GB DDR4 (2100)
8 GB DDR4 (2100)
