I am running the new release, 1.51.  First tab, Input, I see the headings across the top of the list of files, but the view I have is only a thumbnail.  I do not see a button or pull-down or anything else that will change the view.
The problem it is causing at the moment is that I cannot read the filename.  I can by hovering over each file, but that isn't quite what I want.
Can someone help me change my view?
						How do you change the view of the "Input Files"?
				MikeTheWatchGuy
Re: How do you change the view of the "Input Files"?
This feature does not exist (yet)...It is also a feature I requested too but I think Pierre was having problems coding it.
