transitions not applied to saved slideshow
efpob
Post by efpob »
If I open xnview normally, open a saved slide show and run it, it works fine
If I run xview from the command line, c:\program files\xnview.exe -slide c:\slide.xns
The saved slide show runs, but it ignores any transition effects and performs a simple cut
