Can't display SVG files
klumy
Post by klumy »
XNView 1.8 can't display SVG files
I used the SVG files on
http://www.openclipart.org/downloads/
XNView 1.91.5
Windows XP SP3
Olive
Post by Olive »
SVGs are kinda 'special' graphic files. More a feature request than an actual bug IMO :)
Re: XV 1.8 bug: can't display SVG files
klumy wrote:XNView 1.8 can't display SVG files
Do you have tried with the CADImage plugin??
klumy
Post by klumy »
where can I find this plugin?
XNView 1.91.5
Windows XP SP3
klumy wrote:where can I find this plugin?
In complete setup or zip, or here:
http://download.xnview.com/XnView-win-plugins.exe
klumy
Post by klumy »
I downloaded the complete Setup, but it doesn't work :(
XNView 1.91.5
Windows XP SP3
klumy wrote:I downloaded the complete Setup, but it doesn't work :(
Could you send a SVG file?
klumy
Post by klumy »
XNView 1.91.5
Windows XP SP3
ckit
Post by ckit »
I can confirm this as well - XnView gives error message and there is no thumbnail for the file.
Both IrfanView and PhotoFiltre can't view it either!
I've downloaded other SVG's from http://clipart.freedesktop.org/index.php and they don't work either.
I tried enabling "Use all formats" at startup and still no luck.
klumy
Post by klumy »
BTW
the clipart is from the Open Clip Art Library
http://openclipart.org/downloads/index.php
XNView 1.91.5
Windows XP SP3
xnview wrote:
I can't download it
Ok, i have it, and i'll ask the third party plugin author...
difo.pol
SVG
Post by difo.pol »
is there a plugin to read svg - files ?
Olive
Post by Olive »
*Peanuts* here…
>> Olive
:) Hello !
- I could download the samples alright, but that doesn't work here, while the CADimage.DLL plugin is present…
- I suppose that the plugin needs an upgrade… ?
- Under Win 98 SE - XnView 1.80.1
:mrgreen: Kind regards,
