SlideShow from folder with change of files
sartaros
Post by sartaros »
It would be very useful to be able to make slideshow from the folder in which files change. The order may be the file creation time.
Something like this http://newsgroup.xnview.com/viewtopic.php?p=61854#61854
Thanks
Re: SlideShow from folder with change of files
you means that list of files change?
sartaros
Post by sartaros »
xnview wrote:you means that list of files change?
Yes it is. List of files change automatically. Slidesow works with the fixed list now. There will be an error, when some files was deleted. Such possibility would be very demonstrative
but it's already possible 'watch for new images'
sartaros
Post by sartaros »
xnview wrote:but it's already possible 'watch for new images'
that's great. I used the old version, so it's my bug, sorry. I can offer other improvement.
How to choose some images from slidesow series? it is enough to press ENTER, while images slide on a screen. Xnview open chosen image as a reaction on pressing ENTER for next viewing
