HD Photo Format is somehow broken
unquestioned2
Post by unquestioned2 »
I have a JPG-File with the dimensions 4320x3240(x24).
I store it with XnView 1.99.1 as WDP-File (which means HD Photo) with a quality of 82%.
That works all. But I can not open it with XnView again.
I can't open the new WDP-File with XnView (or with Corel Photo-Paint X6.1 for example).
But it's still possible to open the new file with Windows (7) (with the included Windows Photo Viewer).
The error "message" which appears if I try to open it with XnView looks like this:
Please fix this (if possible)!
Re: HD Photo Format is somehow broken
could you send me the jpeg + wdp files?
Drahken
Post by Drahken »
I've run in to the same problem. However, I found a workaround & perhaps a clue to whatever might be causing it.
Open a WDP created by xnview directly from explorer, you get the blank error popup.
Open xnview, use the open dialog, select "all files", you get the blank error popup. (Also of note, when you select the image/s, there is no preview image in the open dialog.)
Open xnview, use the open dialog, select "WDP", the image will open properly (and will show the preview on the open dialog).
I have tried this with both the "recognize only by extension" option checked and unchecked, results are the same.
Another, possibly related, error is that if you select "JXR" on the open dialog, both JXR and WDP images will be shown in the file list (although WDP images cannot be opened this way, the result is the same as if "all files" were selected).
example image: http://allspark.net/cypherswipe/stonehenge.wdp
I am currently using xnview v1.99.1.
edit: I just installed 1.99.6 and most of the errors seem to have been fixed already. The only one left is when you select "JXR" in the open dialog. It still includes WDP images, but won't open them. Attempts to do so result in the standard "cannot be determined" message. The result is the same regardless whether recognize by extension is selected or not. (And "display all types" is already enabled, even though the error message suggests enabling it.)
