After scanning the documents, if you keep all the documents via the "Save open files", the file somehow saved in .PNG, how to change to .jpeg ?
Thx in advice
Document scanning
Re: Document scanning
Here but there is a bug...
sybot
So... when will be fix ?
This bug is the worstest I have seen before
