Batch processing bug -- canvas resize with TIFF output
heepo
I used batch processing to apply canvas resize on my PNG files and choose TIFF as output format. The size of TIFF files are remain the same as canvas resize never apply.
heepo
Re: Batch processing bug -- canvas resize with TIFF output
Additional :
The bug occurs only when the canvas-resized image larger than its source. In case of smaller output, the output is cropped correctly as it should.
Could you post the tiff file and script?
heepo
Ok, it's a problem with alpha (bad value)
