Hi
i really like xnconvert , i don't like a lot the thumbs because they are very small but
it's really a great software
i tried to crop/eliminate white border/frame around some picture
i used automatic crop , tollerance 0 , and every kind of setting color of pixel @ and color
it doesn't eliminate the frame ,it autocrop a piece of the border, and it leaves a tiny part of the white border
other atomatic crop actions don't eliminate it!
is there way to get rid of this white border ? in same case is black
thanks
Re: eliminate white boder/frame
could you post the picture used?
drugo
yes Pierrexnview wrote:could you post the picture used?
are big enough? or should i upload bigger size?
thanks!
no link??
drugo
i removedxnview wrote:no link??
i found the tollerance 0 doesn't make different
i have to set 99 ,and in many cases does its job
but i have many scanned films with a black border , and 99 is not enough , i can do with xnview because i can rise the torrelance
please send me a link of an example?
