Plugins don't show in XnView
chzuck
I downloaded the plugins and put them all in the plugin folder. When I open the program and scroll down to plugin nothing happens. What could I have done wrong?
Peter2
Re: Plugins don't show in XnView
A semi-manual installation? have you tried to download the full-package and install it?chzuck wrote:...and put them all in the plugin folder. ...
Peter
chzuck
I downloaded All Plugins V1.90zip and extracted the files to the plugins folder per the instructions. When I go into windows explorer the files are there under plugins, but when in the XnView program and I click on plugins, nothing happens.
Plugins are plugins for formats, not addon for XnView (Plugin menu)
http://www.xnview.com/en/addons.html
The FAQ 'Let's talk about Plug-Ins... ...and AddOns' might be worth while reading when encountering problems with Plug-Ins or Add-Ons.
chzuck
Thanks I will check that out. Looks like lots of good information that I could use.
