could be added text in many color?
drugo
Post by drugo »
Hi
about text could be added a multi color text feature?
for example like this ?
julie smith 's phography
thanks
Re: could be added text in many color?
currently not possible, but you can have 2 add text
drugo
Post by drugo »
xnview wrote:currently not possible, but you can have 2 add text
yes thanks
but it doesn't work if i want to batch many file and add this text on the left "corner xnconvert job"
Possibly with XnConvert with two successive 'Text' actions?
drugo
Post by drugo »
cday wrote:Possibly with XnConvert with two successive 'Text' actions?
yes i got it
try to add 2 successive text actions with photos with dirrent size and create a "XNconvert 's job" -> bottom right
or change the resize ratio...
