Cannot install - Installer exits
alexgieg
- Yahoo Messenger: [email protected]
I'm trying to install XnView 1.99.5 in this WinXP SP-3 machine, but whenever I double-click the installer it opens briefly (I can see the language selection drop down) then exits. I tried with the full and standard installers, in both the most recent v1.99.5 and the slightly older v1.99.1 versions, with and without my anti-virus' realtime scan enabled, but the result is the same. Is there something I can do other than going for the Zip version? I'd love to have XnView installed properly.
Thanks!
Thanks!
Re: Cannot install - Installer exits
Strange, you are the first user with this problem... And in admin account?
alexgieg
Yes. It's a domain account with full local admin privileges.
I've seen a similar problem of a program opening and then immediately closing in Windows 7 when I've tried to run .chm (Compiled HTML Help) files.
The problem occurred because the file was 'blocked' for security reasons and the solution was to unblock it by right clicking on the file, selecting Properties | General and then clicking on 'Unblock'.
The XnView.exe installer is similarly shown as blocked in Windows 7, but it can be installed without unblocking as the installation starts with a screen advising that the file comes from another computer and asking for confirmation that it should be installed.
So in Windows XP Sp3 it might be worth right clicking on the installer file and checking if it is shown as blocked...
alexgieg
No, unfortunately that isn't it. The installer is already unblocked, and I even went into the advanced permissions and granted full access to it for all account levels, but no luck: it still briefly opens when double-clicked then in about half a second or less closes.
The problem you describe is exactly the problem I had that was solved by unblocking the file; I presume that you have actually seen the file marked as 'blocked' and then unblocked it.
Looking on the Internet, it looks as if blocking was introduced to try to prevent piracy through illegal media file downloads and was related to the different regions.
If you are really the only person to have encountered this problem, I wonder if it could be anything to do with the fact that you are in Brazil -- could your copy of Windows possibly not allow unblocking, for example?
Anyone any ideas?
Anyone any ideas?
alexgieg
That's certainly not it, since I have many applications installed, both paid and free, from the simple to the power user level. In fact, I install and uninstall stuff all the time, and so far XnView and XnView Shell are the only two executable installers I've found that start then close without allowing the installation to proceed. Also, I have it installed in two other machines, a WinXP box similar to this one and a Win7-64, both with similar sets of installed software, and in both it installed fine.
Quite puzzling, isn't it?
Hmm... I'm starting to wonder whether this is one of those odd cases in which the actual solution is to do a clean OS reinstall because some obscure DLL is corrupted...
- Forum Librarian
Are there any log files left behind in your %TMP%/%TEMP% folder(s) after the failed installation, alexgieg?
Setup crashes wrote:On a computer our setup (Inno 5.2.3) quits immediately, without any error messages. On all other machines we have no problems with the same setup.
alexgieg
Sorry for the delay. Last Friday plus the weekend were an extended holiday here. I couldn't find a log file in my %TEMP%, so I googled around on how to manually create one (easy enough: just a matter of running the setup with a /LOG="log.txt" parameter added). Here's the end result. Unfortunately, it isn't very informative:
And here's the shell installer one, which also exits after started:
Finally, within the folder mentioned in the last line above I only found this:
The "_RegDLL.tmp" file being a binary blob, hence also not much informative (I think?).
2012-11-05 09:57:43.347 Log opened. (Time zone: UTC-02:00)
2012-11-05 09:57:43.347 Setup version: Inno Setup version 5.3.9 (a)
2012-11-05 09:57:43.347 Original Setup EXE: C:\Documents and Settings\alexander.gieg\Meus documentos\Downloads\Novos\XnView-win-full.exe
2012-11-05 09:57:43.347 Setup command line: /SL5="$F03AE,14654366,76288,C:\Documents and Settings\alexander.gieg\Meus documentos\Downloads\Novos\XnView-win-full.exe" /LOG="log.txt"
2012-11-05 09:57:43.347 Windows version: 5.1.2600 SP3 (NT platform: Yes)
2012-11-05 09:57:43.347 64-bit Windows: No
2012-11-05 09:57:43.347 Processor architecture: x86
2012-11-05 09:57:43.347 User privileges: Administrative
2012-11-05 09:57:43.425 Got EAbort exception.
2012-11-05 09:57:43.425 Deinitializing Setup.
2012-11-05 09:57:43.425 Log closed.
2012-11-05 10:06:15.000 Log opened. (Time zone: UTC-02:00)
2012-11-05 10:06:15.000 Setup version: Inno Setup version 5.3.9 (a)
2012-11-05 10:06:15.000 Original Setup EXE: C:\Documents and Settings\alexander.gieg\Meus documentos\Downloads\Novos\XnShellEx.exe
2012-11-05 10:06:15.000 Setup command line: /SL5="$F03C8,745933,76288,C:\Documents and Settings\alexander.gieg\Meus documentos\Downloads\Novos\XnShellEx.exe" /LOG="log.txt"
2012-11-05 10:06:15.000 Windows version: 5.1.2600 SP3 (NT platform: Yes)
2012-11-05 10:06:15.000 64-bit Windows: No
2012-11-05 10:06:15.000 Processor architecture: x86
2012-11-05 10:06:15.000 User privileges: Administrative
2012-11-05 10:06:15.000 64-bit install mode: No
2012-11-05 10:06:15.000 Created temporary directory: C:\DOCUME~1\ALEXAN~1.GIE\CONFIG~1\Temp\is-C922C.tmp
%TEMP%\is-C922C.tmp\
%TEMP%\is-C922C.tmp\_isetup\
%TEMP%\is-C922C.tmp\_isetup\_RegDLL.tmp
%TEMP%\is-C922C.tmp\_isetup\_shfoldr.dll
- Forum Librarian
I have no idea )-:
According to innounp, all current XnView installation packages were compiled with Inno Setup v5.3.9 ANSI (10/Apr/2010). However, v5.5.2 (08/Oct/2012) is the latest release.
- JR Software
- Newsgroups: Search for got eabort exception
- Inno Setup Help: Setup Command Line Parameters
- Google Search for "got eabort exception" "deinitializing setup"
- pdfforge Forums: 1-5-0 setup not running on XP
- Vembu StoreGrid Forums: Help with Silent switches please.
- LokSim-Forum: Loksim 2.8
- Forum Librarian
It may also be worth a try to (backup and then) delete all registry entries in HKEY_CURRENT_USER\Software\XnView\.
Download URL / filesize / MD5 checksum (generated with SendTo MD5):
http://download.xnview.com/XnView-win-small.exe | 02'563'170 | 6fbff51c7573c14ec9c321f0824214db
http://download.xnview.com/XnView-win.exe | 04'578'322 | 7fa371916be5d0f210031602291749fc
http://download.xnview.com/XnView-win-full.exe | 14'932'798 | 4277d773a46a399314c86f365c938b07
http://download.xnview.com/XnShellEx.exe | 01'000'523 | 9929caf1a5d8350e84615b6cfbca0047-
hbobenicio
I'm having the exactly the same problem right now... Did you solve it, alexgieg?
DOS386
I never had this problem, but there is a splendid solution: download the ZIP http://www.xnview.com/en/xnview/#downloads
alexgieg
No. After a while I had to reformat my computer for other reasons and in such a clean system it installed without issue, but that doesn't really count as solving...hbobenicio wrote:I'm having the exactly the same problem right now... Did you solve it, alexgieg?
