Renaming/Customizing Colour Labels
chieri
Post by chieri »
hello!
Would it be possible for the user to rename/customize Colour Labels? Does this feature already exist?
Example: We have customers that request that their artwork be "rushed" because they have a presentation due in a hour.
User could rename colour label "rush" and have set to default option if we needed to reset it back. Which probably wont be the case if we can customize it to individual usage.
Re: Renaming/Customizeing Colour Labels
you can change them int the .ini
[Browser]
ColorLabel-1=...
ColorLabel-2=...
chieri
Post by chieri »
Brilliant. Thank you.
