I´m using XnView 1.99.5 on Win XP SP3 and noticed a crash after the following workflow:
- Make a screenshot by pressing Alt+Print
- Paste via Ctrl+Shift+V into XnView
- Save as PNG
- Close XnView
The problem obviously is that I close XnView while it is still saving the image. I get asked if I want to save changes, click "no" and then XnView crashes.
Lars
Crash on closing when XnView is still saving
Re: Crash on closing when XnView is still saving
You are able to close XnView while saving, here i can't?
larsen
Sorry, I was unprecise: I click on the "X" to close the window.
