Fullscreen & taskbar
maria
Post by maria »
Ola,
I have checked General - Startup - Start View in Fullscreen, but usually it takes few seconds until XnView hides the windows taskbar. I have been using ACDSee 2.XX since last century and this anyones me very much, because ACDSee doesn't has this problem. Can I do something to change described behavior? This and better command line in ACDSee keeps me from switching, I am missing "Specifying images to view" ACDSee command line option. Any help will be appreciated.
Sorry for my bad English.
ckit
Post by ckit »
Try turning off "High Quality Zoom for Fit to Window/Desktop" and "Use delayed high quality for pictures larger than (pixel)
Disable "Use all formats available" as well.
Set "Auto Image Size for Fullscreen" to "No Fit"
maria
Post by maria »
Ola,
I only needed to turn of "Use delayed high quality for pictures larger
than (pixel)", but there is no noticeable difference if I do so.
maria wrote:I only needed to turn of "Use delayed high quality for pictures larger
Could try to disabled options/View/High zoom quality/Reduce
VuDu
Post by VuDu »
if you do so, the image will get pixelized when resizing to desktop. that doesn't happen on ACDSee like maria said.
is XnView doing anything wrong/slower?
Ad decus et ad libertatem nati sumus
Aut haec teneamus aut cum dignitate moriamur
Hacker
Post by Hacker »
Actually, I don't think I have ever seen any other soft than ACDSee to hide the taskbar so fast.
