TreeView not working?
Rebellious
Post by Rebellious »
Clicking in TreeView does not expand folder tree. Same thing when loading dir form command line.
I know it used to work, except for networks, but even that worked after adding CheckNetFolder/ExpandUNC.
Any ideas? I'm running Win2k in VM under 64-bit Linux.
Re: TreeView not working?
Nothing happened if you click on the treeview's item?
I can't reproduce it on Win2K
Rebellious
xnview wrote:Nothing happened if you click on the treeview's item?
Thanks Pierre, I was using "UI-less settings" expandunc/checknetfolder from http://www.xnview.com/wiki/index.php/UI-less_Settings
I remeoved these and TreeView works again.
