In Windows Explorer there is an additional timestamp which shows when a file has been last accessed.
I think this times stamp is quite useful. It would be great to have a last accessed timestamp in xnviewmp as well. However it might not use the Windows Explorer timestamp data as this would change every time xnviewmp loads a file to create a thumbnail.
So it should me be like a timestamp reflecting a true access of a file from within xnviewmp.
Suggestion additional timestamp
Re: Suggestion additional timestamp
you means in the detail view?
soulky
Yes in detail view. Then it would be possible to sort them by last accessed file. But as said I believe it should only show a files as accessed when it has been launched from within xnviewmp. If Winodws Explorer timestamp will be used, then everytime a thumbnail gets created would produce a new timestamp for the file which is not a real access.xnview wrote:you means in the detail view?
