Contact Sheet Size Adjustment
dan
with version 1.80, when selecting 4 images, I have the dimensions set at 800 x 600, margins 10 pixels x 10 pixels, in 2 columns and 2 rows, spacing 20 pixels x 20 pixels, but when i click on create contact sheet, the images are very small. in XnView v1.74 and all earlier versions the above settings would create 4, 3.5 inch x 5.0 inch image.
Re: Contact Sheet Size Adjustment
Strange i did not change anything, could you post your sample?dan wrote:with version 1.80, when selecting 4 images, I have the dimensions set at 800 x 600, margins 10 pixels x 10 pixels, in 2 columns and 2 rows, spacing 20 pixels x 20 pixels, but when i click on create contact sheet, the images are very small. in XnView v1.74 and all earlier versions the above settings would create 4, 3.5 inch x 5.0 inch image.
Anika
I had the same problem. But I know the reason:
I had the setting to show in the browser the embedded thumbnails. If I uncheck this the thumbnail is generated by XnView and the contact sheet looks as it should with normal size.
Hope this is the right solution. But it is strange.
XnView 2.04, 2.13 Windows 2000 SP4 and Windows XP SP3 and Windows 7 64bit
Ok, now i understand, aAnika wrote:I had the same problem. But I know the reason:
