Fit image to desktop, large only (from normal xnview)
sacharja
Post by sacharja »
please integrate the "Fit image to desktop, large only" feature from the normal xnview in xnview MP.
Also it would be great to hide the menu bar just in viewer. These are the 2 things that prevent me from using MP as the main image viewer. Maybe someone has a status on these ones or knows if these are going to be implemented? I know someone asked about this a few years ago.
Greetz
sacharja
Re: Fit image to desktop, large only (from normal xnview)
Post by sacharja »
I like the idea of being able to browse through my gallery while also seeing what's going on on desktop. No other big image viewer is capable of doing this (the last was ACDSee v10).
Rebellious
Post by Rebellious »
That should be the default setting, on my Linux system this option keeps changing back to the 1st "fit image to window".
sacharja
Post by sacharja »
Indeed, however I only know 2 applications that have this behavior as standard. One of them doesn't even offer a menu bar (both have no file browser). Concerning Linux and v1.9x: maybe there's a problem with the Unity desktop (Ubuntu), can you reduce normal windows?
sacharja
Post by sacharja »
Fit image to desktop is the standard behavior of IrfanView (however that is not an option because it has no real browser).
Would even be great to know why it takes so long to implement this. Is it because it's complex or can we never expect that in XnView MP?
In XnViewMP, it's not easy to implement that
Webum
Post by Webum »
Any progress with "Fit image to desktop, large only" ?
