Problems with the slide show
Greina
Post by Greina »
Hi, I am new here.
I just stated the following problem:
I selected the slide show and loaded a folder with some links to jpg files. XNView shows them as abcd.jpg.lnk
But XNView crashes when I want to start the slide show.
Re: Problems with the slide show
Do you use 'Add folder'?
Greina
Post by Greina »
Yes! I add a folder with some (working) links to jpg files. Then I click on start and XNView crashes.
In the case I add some files (=links to jpg files) the problem is similar: XN view accepts the selection. Then I click on start and I get an error report: XNView is not able to recognize the selected file format.
Greina
Post by Greina »
Any idea???
I can't reproduce, if you add for example 2 links (of jpeg), you have a crash?
noori
Post by noori »
xnview wrote:I can't reproduce, if you add for example 2 links (of jpeg), you have a crash?
Same issue is here with me can any one suggest us a solution
