XnView hangs on 0-byte AVI
Phant
Post by Phant »
Hi!
When you try to open a file with the extension .AVI that actually doesn't have any contents (0 bytes), XnView hangs. You can only kill the task and restart XnView. The problem does not occur with another file extension, e.g. .JPG.
(XnView v1.99.5, Windows 7 x64)
Greetings
Phant
Re: XnView hangs on 0-byte AVI
I can't reproduce, you have that when you click on this avi in the browser of XnView?
Hmm, no problem with XnView 1.99.6 on Windows XP.
