0.51 win-x86: Small bugs with "Save" command
budz45
Post by budz45 »
A.) The "Save" command in view mode should be greyed out for when Empty Tab
B.) The "Save" shortcut of Ctrl+S does not work immediately as it should after doing a Screen capture with the "Capture" tool.
1.) Run a 'clean' XnView MP 0.51 x86
2.) Make sure XnView MP opens with 'Empty tab' (so disable "open browser" in Settings>General)
4.) Now take a screenshot of your Desktop using XnView MP "Capture" with default capture settings
5.) Once the screenshot is captured, now try to use the shortcut Ctrl+S to save the picture....
6.) The Ctrl+S shortcut does not work...However...
7.) ....The shortcut only works after going to File>Save dialog, then after cancelling save use Ctrl+S and it now works.
Small bug with Ctrl+S not working the first time with new Captures
Windows 7 sp1
budz45
Re: 0.51 win-x86: Small bugs with "Save" command
Post by budz45 »
Thank you. Both Fixed in XnViewMP 0.56 :)
