Regain individual images from exe/scr application
mookx
Post by mookx »
Is there a way to regain individual images from an exe/scr application?
Re: exe/scr
mookx wrote:Is there a way to regain individual images from an exe/scr application?
you can press S key
mookx
Re: Regain individual images from exe/scr application
Post by mookx »
I press the "S" key while the slideshow is running. Nothing happens. What I need to find out is can I access the individual images in the slideshow apart from the Print Screen function which is tedious.
the slideshow is created with 1.99?
mookx
Post by mookx »
With version 1.98.2 or the previous version.
sorry it's E key
mookx
Post by mookx »
Could you please be more specific. I set the slideshow in motion and press the E key and nothing happens. What I am asking is how do I extract individual images out of the slideshow. I need a detailed explanation of how to do this. Your explanation of "Press the E key" is not working for me. Thank you for your patience.
mookx
Post by mookx »
Okay thanks I got it to work ... but only on some of the slideshows????
you have not all pictures?
mookx
Post by mookx »
It works with some of the exe/scr that I have. I get all the pictures ... but it doesn't work at all with many of them.
perhaps some exe created with an old version?
