If I am opening in XnView to my desktop, XnView crashes:
The problem signature is:
Problemereignisname: APPCRASH
Anwendungsname: xnview.exe
Anwendungsversion: 1.99.0.0
Anwendungszeitstempel: 50477247
Fehlermodulname: CADImage.DLL
Fehlermodulversion: 8.2.0.1
Fehlermodulzeitstempel: 500900b8
Ausnahmecode: c0000005
Ausnahmeoffset: 000047db
Betriebsystemversion: 6.1.7601.2.1.0.768.3
Gebietsschema-ID: 2055
Zusatzinformation 1: 6bcd
Zusatzinformation 2: 6bcde7812013385e3f8c6e4751551664
Zusatzinformation 3: 74ae
Zusatzinformation 4: 74ae7addc4386071184d4205999ccb79
If I am doing a double click on a png file the same with:
Fehlermodulname: ntdll.dll
Fehlermodulversion: 6.1.7601.17725
Fehlermodulzeitstempel: 4ec49b8f
Ausnahmecode: c0000420
Ausnahmeoffset: 000ce6c3
Zusatzinformation 1: 44e0
Zusatzinformation 2: 44e01c3187022e070f3e82fc81bc0af9
Zusatzinformation 3: ff7d
Zusatzinformation 4: ff7dff9f76ba0a1013abbe98ca05ebe7
Double clicks on jpg Files are working. It's an installation on a Windows7 64bit system. I have already deinstalled XnView and installed again, but the effect is the same.
Axel
Application Crash on Windows 7 64 bits
Re: Application Crash on Windows 7 64 bits
Please try to rename the Plguins folder of XnView?
Merlin3322
Hi Pierre,
I have done it and it's working now. What are the consequences now ?
Best regards
Axel
Best regards
Axel
The folder opened in xnview's browser, do you have CAD files (dxf, dwg, hpgl)?
Merlin3322
Only svg files, but they are not associated with XnView.
Axel
Axel
So you have a svg that crash XnView
Merlin3322
You can download the file here:
https://dl.dropbox.com/u/24723081/test.svg
It's an svg created with Inkscape
Axel
Axel
